THOMSON VPH-6790
Username: Eben1000uk
England, United Kingdom
hi there. i just bought a THOMSON VPH-6790 vcr at a car boot sale. it seems to work ok, but there is no user manual. what i want to do is connect my video camera to the arial input on the VPH-6790 and record it to vc. the problem is i dont know how the tune the video machine to the correct frequency for the camera. can anyone help, or maybe link to the user's guide?
many thanks!
eben
Username: Ieee488
Post Number: 706
You can't do what you are wanting to do.
really? why not - can you give me any more information?
Username: Ieee488
Post Number: 708
Give me the model of your video camera.
The aerial input of a VCR is for TV signals.
Your video camera does not output TV signals.
its a phillips v100 camera that has a rf signal output on an arial socket. i have used the camera with my tv monitor [via arial in] but had to tune the channel frequency manually on the tv to get the picture. i wanted to use the thomson vcr to record the video camera. does this make sense? i need to be able to tune the thomson vcr to the correct frequency like i did on my tv, but without the user guide i cant work out how to do this. many thanks
Username: Ieee488
Post Number: 709
whichever TV channel you tuned to on your TV would also be the same channel to use on the VCR
if there is a channel up/down button the VCR, I would keep pressing it and hope you hit upon the channel
Need to Register?
Forgot Password?
Enable HTML code in message
