HLN467WX/XAA board issue
Username: Smason28
Okay, I have been looking for some advice on which route to go with my HLN467WX. I recently bout it and it supposedly had a bad lamp. So i replaced the lamp...While replacing the lamp i find there is another problem, no color wheel. So I replace the color wheel and when i went to plug the color wheel into the board the clasps that hold the connectors on the board had been broken off. Would replacing the board be the best/easiest fix? or is there another route I should look into? if the board is the route does anyone know the part number of the board? the last thing i need is to buy something that doesnt work with the model tv I have. Any help is much appreciated. Thanks. (ps. I'm new in this forum, sorry if description is bad...have pics if needed.)
Need to Register?
Forgot Password?
Enable HTML code in message
