CD/DVD player's audio
Username: Myuser
Dear All
Its long time I have a problem with my CD player when connecting to my Daewoo LCD TV.
When I play a video CD, I use a RCA cable for video and audio, subsequently I could watch the video on screen and listen to it via TV inline speaker.
But the problem is that when I play an audio CD, I could not listen to it via TV.
I used RCA cable to connect red and white colors for Left-Right audio, but it didnt work.
I used the port "PC Audio" on the back of TV, but it also didn't work.
Is there any idea?
Isn't possible to play an audio CD and listen it via TV?
Username: Ieee488
Post Number: 680
Your TV may be detecting that there is not video signal so it doesn't do anything with the audio input.
Username: Myuser
Thank you for your answer. I agree with you, but isn't there any other solution?
Username: Ieee488
Post Number: 681
I suppose you a 2nd DVD player to provide the video signal to fake out the TV. Seems a lot of trouble for mediocre sound.
Need to Register?
Forgot Password?
Enable HTML code in message
