LCD TV power supply issue?
Username: Jchin92
i was repairing a 26AV500U Toshiba and it had no picture but sound, shined a flash light and saw a picture. so i thought i was the inverter, so i replaced it and it worked for like 2-3 days then went out. so im asking if its a power supply issue before i get it replaced and if my inverter is goood or not.
Username: Ram_rod
Fayetteville, Arkansas
How old is the TV? It is sort of odd it did work for a few days. It could be your inverter is not getting the correct primary voltage. Lamps do go bad eventually, but most times they just go out for good.
Username: Jchin92
tvs about 3 years old. i had a new power supply and inverter. but i heard inverters do fail easily like that. or maybe the bulbs are just gone? cuz after watchings maybe 20 minute of tv it goes out.
Need to Register?
Forgot Password?
Enable HTML code in message
