VCR and TV not working together. Please help if you can
Username: Pathy
We are trying to hook up a vcr to a philips magnavox tv. I believe I have it connected correctly but we cant figure out how to set the tv to play the vcr. the external option in teh menu for the vcr is selected but nothing is happening. Its only the vcr we are putting on this tv. We also have no remote for either tv or vcr.
Username: Plymouth
Post Number: 16250
Welcome to eCoustics Pathy!
Please give us the model of your VCR and your TV, it will help us to help you!
Username: Pathy
The TV is a Philips Magnavox model number TS27 46 C101 and the VCR is a RCA Accu Search Model number VR637HF
Thank you for the welcome. I am really happy I found this site :D
Username: Ieee488
Post Number: 607
You might be able to select the TV's video source by pressing the TV front panel's channel up/down buttons. You'll want to set the "channel" to LINE1 or LINE2 or something like that which is where the VCR is connected.
If that doesn't work or the TV doesn't have buttons you can push, then you'll need to find the remote for it.
I can't find manuals online for either the TV or the VCR, so if you have a paper copy, I suggest you read it.
Username: Pathy
ieee ... I have before pressed the buttons on the front and gotten into the menu. There is a option for VCR and separate one for DVD. I still cant get it to work with the vcr.
I have no paper manuals for with devices
Username: Ieee488
Post Number: 614
download and read the VCR's manual
http://tv.manualsonline.com/manuals/mfg/rca/vr637hf.html
Need to Register?
Forgot Password?
Enable HTML code in message
