Mitsubishi HD1080 Black Screen Problem
Username: Tkay
I have an older Mitsubishi HD1080 and the tv sound comes on but the screen is black. When the display comes on showing the "antenae on" or "cable on" notification I get double vision and the words are in different colors (red and green) and then it disappears to black. No picture is visible at all, only the channel display that appears for 3 seconds or so when you first power up the tv. Any thoughts?
Username: Plymouth
Post Number: 15486
Welcome to eCoustics tkay!
Usualy you must replace the convergence chips or convergence Eprom, the TV goes in protect mode due to bad convergence to protect the tube damage.
Check this link, I hope that it help you!
http://www.fixya.com/support/t3215656-tv_picture_arches_top_amp_btm
Need to Register?
Forgot Password?
Enable HTML code in message
