Echostar 3 at 61.5
Username: Robbie12
Post Number: 129
hi, is it possible to capture the echostar 3 at 61.5 in vancouver, canada? if yes, what are the settings for the 9000 hd?
i have been trying to get the signal but no luck, i am using a 24 inches dish which was working properly for echostar 10/11 at 110.
thank you.
Username: Nydas
Post Number: 19410
The footprint of 61.5W shows that Vancouver is covered. You might try a 30-33" dish
http://www.satbeams.com/footprints
Username: Robbie12
Post Number: 130
i will do that, thank you nydas. you are always helpful.
Username: Plymouth
Post Number: 14441
Robert
Get a 36'' you will have a better signal!
Username: Robbie12
Post Number: 131
ok, i bought a 36 inches dish, i am using the same lnb for 110/119.
my settings are : standard, 11250 and still no luck, what is the issue?
Username: Chaff
Post Number: 492
You could ...go here,http://www.lyngsat.com/packages/dish61.html , look for TP with conus beam and use that TP in antenna settings when aiming the dish
The HD TP's are 8psk, sr 21500, fec 2/3
Username: Robbie12
Post Number: 132
ok, i have got the signal from 61.5
i made a channel scan, i got 33 channels but none of them is working!
all are scrambled channels, aren't those channels supposed to work with the weather forecaster?
Username: Nydas
Post Number: 19413
I think the WF and most IKS only give you 110/119/118
Username: Robbie12
Post Number: 133
why i did not think of this issue before buying the dish.
anyway, thank you for the help.
Username: Plymouth
Post Number: 14449
Robert
Sorry! I don't have the latest channel list!
Which channels you are looking for?
You can use this dish to get some free to air channels!
Username: Robbie12
Post Number: 134
i am looking for the Arabic Package (al arabiya, mbc, lbc ....)
Username: Chaff
Post Number: 493
You could.. . check the 118 sat , it might have the channels you want-,
if so , get new lnb ("Circular" 118°/119° 10750) for the 36" dish and aim at that sat.
Username: Nydas
Post Number: 19415
Robert: Re. Arabic channels. Just to avoid cconfusion.
With a DN subscription, and IF the arabic package is on 65W, you should be able to get it with a larger dish because of the weaker signal in the West coast. You WILL also need a Dish receiver with current subscription paid for those channels.
If you are looking for Arabic channels via IKS on a FTA receiver, this is only available from 118W (ANIK F3). For that you need the 33" dish, a special 118/119 LNB with LNB freq. of 10750 0r 10600..
Also note that as if now, the IKS support for 118 is down. There is upport only at 119 and possible for 110W.
Username: Pancho_vilia
Post Number: 30
Robert Pelligrini
point you Dish to Galaxy 19 at 97.0°W
change your LNB to Linear,pop an Arabic Beer watch
Arabic TV
All FTA Ku-band channels in Arabic
Note
There are a lot of Arabic channels available on North American FTA, more than any other non-English language.
Channel Name /Satellite Freq /Pol SR VPID APID
2M TV www Galaxy 19 11991-V 22000 272 273
Abu Dhabi Sports www Galaxy 19 12145-V 22000 2026 2036
Al Alam News www Galaxy 19 11836-V 20765 408 356
Al Anwar www Galaxy 19 11929-V 22000 2010 3010
Al Fayhaa www Galaxy 19 11966-H 22000 202 201
Al Hayat www Galaxy 19 12060-H 22000 2010 3010
Al Kalema www Galaxy 19 12115-V 22426 2600 2601
Al Kass www Galaxy 19 12083-V 22000 357 358
Al-Forat www Galaxy 19 12053-V 22000 1376 1377
Al-Iraqiya www Galaxy 19 12145-V 22000 2025 2035
Alkarma TV www Galaxy 19 11789-V 28125 4027 4036
Almaghribya TV Galaxy 19 11789-V 28125 4023 4033
Ashur Satellite TV www Galaxy 19 11929-V 22000 2007 3007
Canal Algerie www Galaxy 19 11789-V 28125 1260 1220
Coptic TV www Galaxy 19 11867-V 22000 4194 4195
Hope Sat TV www Galaxy 19 12090-H 20000 4863 4864
Jordan TV www Galaxy 19 12145-V 22000 2073 2083
Kuwait TV www Galaxy 19 11991-V 22000 320 321
Kuwait TV 3 www Galaxy 19 11789-V 28125 848 849
Libyan Jamahiriya Broadcasting www Galaxy 19 12145-V 22000 2072 2082
LLBN Arabic www Galaxy 19 11842-H 22000 2012 3012
Logos TV www Galaxy 19 11867-V 22000 33 32
Middle Eastern American www Galaxy 19 12115-V 22426 1280 1281
MTA1 www AMC 3 11735-V 8333 102 103
MTA1 +3 hours www AMC 3 11735-V 8333 302 303
MTA3 Al-Arabiyya www AMC 3 11735-V 8333 402 403
Payam-E-Afghan TV www Galaxy 19 12122-H 20000 783 784
Qatar TV www Galaxy 19 12145-V 22000 2071 2081
Salaam TV www Galaxy 19 11929-V 22000 2005 3005
Saudi Arabian TV 1 www Galaxy 19 12145-V 22000 2024 2034
Saudi-Quran Galaxy 19 12152-H 20000 1024 1034
Saudi-Sunnah Galaxy 19 12152-H 20000 1025 1035
Sharjah TV www Galaxy 19 12145-V 22000 2027 2037
Sudanese Space Channel www Galaxy 19 12145-V 22000 2023 2033
Sultanate of Oman TV www Galaxy 19 12145-V 22000 2028 2038
Syria Drama Galaxy 19 11789-V 28125 1104 1105
Syria Satellite Channel www Galaxy 19 12145-V 22000 2021 2031
The Truth www Galaxy 19 12060-H 22000 2024 3024
The Way www Galaxy 19 12022-V 22000 4255 4256
Tunis 7 www Galaxy 19 11836-V 20765 262 263
Yemen TV Galaxy 19 12145-V 22000 2022 2032
Username: Robbie12
Post Number: 135
Hombre, thank you for your help, i already have those channels but the rest i am looking for are better, thank you chaff for your help.
Nydas, those channels are also available on Echostar 14 at 119W, is this satellite supported by the WF?
thank you in advance for your help.
Username: Nydas
Post Number: 19417
"on Echostar 14 at 119W"
Look at this Lyngsat URL. although it says 119 it is really a combo URL for 118.7 (Anik F3) and 119 (Echo 14). If you look at the listing under Frequncy you will find 11715 R tp 1 to 12155 L tp 30. These are all Anik F3 TPs and the Arabiv channels are in that section. The real 119 (Echo 14) listing starts at 12224 R tp 1, and only has American channels.
Look also at the parent URL lyngsat/packages/america.html and you will se that Anik F3 and Echo 14 are listed together at 119.
IKS does support Arabic channels of 118, but at present they are down and have been down for a couple of weeks.
Post Number: 31
Hey Robert check this Link out 4 days ago.
I have no idea what or who is NPFS
http://www.abadss.com/forum/1115-private-iks-servers/141271-thanks-npfs-fo-rthe- arabic-package.html
