Playing Computer DVD Files on DVD Players
Username: Mandyab
I just purchased a DVD camcorder. When I download the files unto my computer and then burn them onto a DVD disk, the movies on the DVD won't play on my DVD player. The player does not recognize the disk. What am I doing wrong?
Username: Ieee488
Post Number: 299
If your camcorder burns the miniDVDs, then you need to finalize that disc before you remove it from your camcorder.
Then use your PC to do a Disc Copy of that small disc onto a regular size DVD disc.
Username: Nency
Post Number: 15
hello... i just want to share one problem with you .. i got one video file its mkv format ... when i write that file on my DVD and after that when i try to on my DVD.. its not playing ... i also done with converter mkv to VOB but.. its also not working ...
waiting for your reply thank you
Home Theater Seating
Username: Ieee488
Post Number: 317
http://club.myce.com/f72/tutorial-dvd-video-file-structure-77646/
Need to Register?
Forgot Password?
Enable HTML code in message
