Connect HD TV to DVR Recorder
Username: Sheilabowen
I have just purchased a new Philips 26 inch LCD HD TV set with built in Freeview tuner
Trying to connect this with my existing Funai DVD / VHS Combo recorder.
The TV has 2 scart outlets (EXT1 and EXT2) and the Funai also has two scart outlets, AV1 and AV2 (Decoder)
Am not running any other set top boxes, decoders or anything else.
Have connected the DVD recorder to EXT 1, as per the TV installation manual suggestion, its has recognised the DVD unit, and I can play DVD's
However, it cannot record...doesn't seem to see AV1 as an input port or pick up channels. Tried running the aerial cable through the DVD but that didnt work either.!
Any help appreciated. thanks
Username: Ieee488
Post Number: 318
ports on the Philips and the Funai are not bidirectional.
output gets connected to an input
and
input gets connected to an output
You must have one connection correct since you can watch your DVD on the TV. In this case, Funai output to TV input.
To record, you need TV output to Funai input
Need to Register?
Forgot Password?
Enable HTML code in message
