Record from TIVO?
Username: Magfan
Post Number: 2013
Any way to record from TIVO onto permanent media?
Plug a drive into small dish receiver, fill 'er up and than move the drive to my PC or MAC?
I kind of miss being able to make permanent copies of stuff, like in the old VCR days.
Username: Samijubal
Post Number: 4323
A standalone DVD recorder. You'll probably need a stabilizer or TBC to remove the copy protection.
Username: Magfan
Post Number: 2018
Thanks, David.
No way to hook up to USB and do a 'data dump'? No way to get at the file system of the Dish box?
A DVD recorder will make an OK copy, I guess, but I'd like to go all digital if possible.
If it helps or hurts, I've got a Mac computer.
Username: Samijubal
Post Number: 4324
If the content is SD you can do it, if it's HD it can't be done. Just use a search engine and you should find what you need if it's SD. You'll have to remove the HDD, I don't think it can be done USB unless you unload it to an external HDD.
I've seen people say it looks the same PC or DVD recorder.
Need to Register?
Forgot Password?
Enable HTML code in message
