InFocus 4805 (DLP) flashing white line 16px wide
Username: Jrumpsa
I received a 4805 from a friend a while back that had this issue, after 5 or so minutes, there is a flickering white line 16 pixels wide on the right. if the screen is displaying bright colors, it remains a constant white. if it is dark, it flickers horribly. And if it is full off (black signal), there is no line. for the first 5 or so minutes that it doesn't appear when first turned on, there are no issues at all. If displaying a bright scene in letterbox, there is a definable difference in the line between the dark area and the light area.
So, my question is, is this a poor solder connection that shows its ugly face after everything has warmed up, or has the signal processor just about had enough?
Need to Register?
Forgot Password?
Enable HTML code in message
