Philips DVD PET741/37
Username: Heci
BA, Buenos Aires Argentina
I bought a Philips 741/37 DVD portable and only work for region 1 , somebody have an unlock prcedure for this DVD it not have remote control.
Thanks Hector
Username: Hardworkinghero
I have the same problem. Did you ever find a solution?
Username: Srg009
Hi, could I ask if anyone ever found a solution for this region fix?
No. I don't think anyone knows the trick.
I even paid DVDexploder to have a look through their rather impressive lists, but no luck there. So, don't repeat my mistake. I will be sure to post it if I ever get the code.
Username: Wpelizzari
Have you guys ever got the code?
Username: Silpg
After several trials, it worked for my Philips PET741/37:
1. Power ON the DVD player without a DISC inside
2. Press the skip keys in this order (the keys are under the "disc menu" and "stop"): right, left, right, left, right, right, left (YOU DON'T HAVE TO GO TO SETUP MENU, just do this in the "blue screen".
3. It will show a menu with region, now use the arrow keys to select "region" and change to "test 0" (all regions).
4. Press OK to confirm. Enjoy
Silmara
Username: Drop67
I tried the procedure from Silmara several times and it only worked from the Preferences Menu (Setup and then Preferences Tab and then press the sequence).
Need to Register?
Forgot Password?
Enable HTML code in message
