Pansonic pt 61lcx70-k lcd rear projection
Username: Billhiggs
Post Number: 8
I have a panasonic lcd rear projection tv, does anyone know how to clean the inside of the screen sand the projector, I used to do it all the time with my old rca crt rear projector,
this house is dusty as well as having 2 smokers in the house, so I am sure the inside of the creen and the projector or whatever is inside is due for cleaning.
Thanks
Username: Lucky101
HydeabadUnited States
Post Number: 17
Following tips might be useful for u.
Remember to always disconnect the power before attempting to clean your rear projection television. You may also want to look through the television manual in order to review any specific cleaning instructions for that model. Don't move around any parts of the television set while cleaning. If you break or misadjust one of the parts, it can prove to be an expensive fix. Also, don't use paper products since they can easily scratch the screen.
Need to Register?
Forgot Password?
Enable HTML code in message
