Silver Member Username: KriskrosPost Number: 123 Registered: May-06 | Just wondering if Nfusion HD will be able to decode Dick streaming in H264 MPEG4 and SD and also current BellVu stream. King previously mentioned that MPEG4 boxes are OK to buy, just wondering if anything changed since then... |
Gold Member Username: RiconissanPost Number: 1900 Registered: Feb-09 | Ask RUSH |
Silver Member Username: JaysonPost Number: 365 Registered: Aug-06 | Ask Oleg PhD.... |
Platinum Member Username: PlymouthCanada Post Number: 10640 Registered: Jan-08 | kris kros NFusion Nuvenio is able to get MPEG-4 H.264 We discussed on it but king says that any receiver will work, but I says to him that Viewsat and few others are able to get it. |
Gold Member Username: RtapFL Post Number: 2370 Registered: Jan-07 | PRODUCT FEATURES * Free to Air Channel Reception from Satellite Broadcasting * IPPVR (Audio & Video Recording to PC via LAN) * Satellite Input - Fully complies with DVB-S MPEG 2 - QPSK (LG NIM Type) - Standard Definition Content (MPEG 2) * 950-2150 MHz Inputer Frequency (IF Loop Throughout) * Satellite Scan - Multisat Scan Support * Flexible Reception of SCPC & MCPC From C/KU-Band Satellites * EPG (Electronic Program Guide) & Channel Naming Supported * Multi Language OSD * Fast Channel Changing Speed * Over 6000 TV & Radio Channels can be stored * Full Color & User Friendly GUI (graphic user interface) for Easy Control * Timer Function & Real Time Clock & PIG (Picture in Graphic) Support * Various Powerful Upgrading Methods - Webloader Downloading via Ethernet Port - RS-232C Cable Downloading - Set to Set Downloading (Main Program & Channel List Data File) * Powerful Channel Editing By - Sorting: Channel Number, Alphabetic, Satellite - Lock, Delete, Move, Edit Channel Name * - 8 Favourite Lists Parental Lock Function Using Master PIN Code * DiSEqC 1.0, 1.2 & USALS / 22 KHz Switching Control Supported * Universal Remote Control Included * High LNB Power Generation TECHNICAL SPECIFICATION - 1 Input Connector : F-type,IEC 169-24 - IF Input Frequency : 950MHz to 2150MHz - IF Loop Throughout : 950MHz to 2150MHz - Input Level : -65 dBm~-25 dBm - DiSEQqC Control : 1.0, 1.2 & USALS Compatible - Band Switch : 22KHz Tone(22 +/- 4KHz. Amplitude : 0.6 +/- 0.2V) - Symbol Rate : DVB-S QPSK : 1-45Msps - Input Voltage : AC 100~250V, 50/60Hz - LNB Power : 13 /18VDC / 1,000mA Max MPEG TRANSPORT STREAM A/V DECODING * Demultiplex : According to ISO/IEC 13818-1(MPEG-2 system) * Aspect Ratio : 4:3, 16:9 * Audio Decoding : ISO/IEC13818-3(MPEG2 Audio/MUSICAM) * Audio Mode : Stereo, Main, Sub * Video Output : RCA, Component, S-VHS (S-Video) MICROPROCESSOR & MEMORY * Main Processor : LSI * CPU Speed : 108 MIPS * Flash Memory : 2 MB + 1 GB (Nand flash memory) * SDRAM : 18 MB + 2 MB DATA PORT * Connector : 9 Pin D-Sub Type * Protocol: RS232 Asynchronous * Data Rate: Max. 19.2Kbps 115.2K * Ethernet : 10BaseT/100BaseTX A/V OUTPUT * Component output : Y/Pb/Pr (RCA) * Video : CVBS output (RCA) * Audio : Stereo L/R output (RCA) * S-VHS : S-Video * Digital Audio : 1 optical output, S/PDIF FRONT PANEL * Smart Card : 1 Slot * 7 keys : Menu, OK, Power, Channel Up/Down, Volume Up/Down REAR PANEL * Ethernet port * IF Input: F-type Connector * Loopthrough Output: F-type Connector * Component output : Y/Pb/Pr * S-VHS : S-Video * 3RCA : Video, Audio L, Audio R * S/PDIF (Optical) for Digital Audio AC-3 Bitstream Output * RF Modulator: 3-4 CH * RS232 Serial Port : 9 Pin Connector, D-Sub Type, Twisted Cable * Power On/Off switch REMOTE COTROL * Type : Super Universal Remote Control * Battery : 2x1.5V AAA Type DIMENSIONS AND WEIGHT * Size : 11.8 (W) x 8.26 (D) x 2.28 (H) [inch], (300 (W) x 210 (D) x 58 (H) [mm]) * Weight (Net) : 5.3 lbs, (2.4 kg) |
Platinum Member Username: PlymouthCanada Post Number: 10649 Registered: Jan-08 | Here is the spec for Nuvenio: * Free To Air Channel Reception Only from Satellite and Terrestrial broadcasting * 2 x USB 2.0, PVR Function Supported : Record & Play with an external HDD * IPPVR (Audio & Video recording to remote PC via LAN) * WebLoader downloading using ethernet port * USB downloading using USB stick * Dual Inputs (Satellite & Terrestrial) : * Fully Complies with ATSC HDTV (VSB) & DVB-S MPEG 2 * ATSC Tuner (LG NIM Type) & QPSK Tuner (LG NIM Type) * Decodes All ATSC HDTV Standard Video Formats * Including 480i / 480p / 720p / 1080i * Selectable Output Video Format : 1080i / 720p / 480p / 480i * Standard Definition/High Definition contents * Free To Air Channel Reception Only from Satellite and Terrestrial broadcasting * 2 x USB 2.0, PVR Function Supported : Record & Play with an external HDD * IPPVR (Audio & Video recording to remote PC via LAN) * WebLoader downloading using ethernet port * USB downloading using USB stick * Dual Inputs (Satellite & Terrestrial) : * Fully Complies with ATSC HDTV (VSB) & DVB-S MPEG 2 * ATSC Tuner (LG NIM Type) & QPSK Tuner (LG NIM Type) * Decodes All ATSC HDTV Standard Video Formats * Including 480i / 480p / 720p / 1080i * Selectable Output Video Format : 1080i / 720p / 480p / 480i * Standard Definition/High Definition contents * (MPEG2 and support MPEG4 AVC/H.264) * High Definition Video Output : HDMI and Component (Y/Pb/Pr) * Audio Decoding : ISO/IEC13818-3(MPEG-2 audio/MUSICAM) Dolby AC-3 * Full compliant of MPEG-S Digital & DVB broadcasting * 950-2150 MHz Input Frequency (IF Loop Throughout) * Satellite Scan * (MPEG2 and support MPEG4 AVC/H.264) * High Definition Video Output : HDMI and Component (Y/Pb/Pr) * Audio Decoding : ISO/IEC13818-3(MPEG-2 audio/MUSICAM) Dolby AC-3 * Full compliant of MPEG-S Digital & DVB broadcasting * 950-2150 MHz Input Frequency (IF Loop Throughout) * Satellite Scan} |
Silver Member Username: ChumleyPost Number: 545 Registered: Dec-08 | Take a look at the azbox elite... claims are that support will be here soon... |
Platinum Member Username: PlymouthCanada Post Number: 10651 Registered: Jan-08 | Yes Chumley (King) But this box is from Europe. |
Silver Member Username: Plymouth_glasserPost Number: 149 Registered: Apr-09 | C/P AzBox High-Defination | AzboxHD USA New Jersey today announced the launch of a new high definition (HD) multimedia receiver to Complement its premier line of HD set-top boxes. The Azbox is an advanced MPEG-4, dual-tuner, DVR receiver with integrated digital over-the-air tuner, and offers the visual clarity and superior surround sound of HD. The receiver will be available to customers in December. The launch of this new receiver provides the Canadian satellite TV market with the latest technology; combining a Digital Video Recorder with a dual tuner and HD. "The new AzboxHD satellite receiver will revolutionize the way our customers watch TV,it leaves the competition in "pause". Our customers can now pause live TV and rewind to create their own instant replays. Plus, the dual tuner offers the ability to record a TV program while watching another channel." Browse true the internet using Wifi or Lan cable connection be able to watch YouTube and much more. |
Silver Member Username: ChumleyPost Number: 547 Registered: Dec-08 | People claim to be using it for NA satellites |
