New member Username: ElpipoPost Number: 1 Registered: Aug-09 | Hi, I see there is at least Plymouth from Quebec City out here. How do we "unfilter" our lines in Quebec? I would like to replace the filter Vide@tron has in the appartment building, and replace it with one that features more channels Now which part (filter) do I purchase, and where? Will I need a descrambler afterwards? How many / which channels can I expect to have afterwards? HDTV available through this? Cheers, Myself P.S. Another question I had was: if I change the filters for all appartments in the building, how will they know I am the one that changed them? P.S.S All respects to Plymouth, and his infinite knowledge |
Platinum Member Username: PlymouthCanada Post Number: 10654 Registered: Jan-08 | Pipo To put out the filter here in Quebec city you will need 2 tools, one for unhook the cable, a thing like a "C" box and the other the extractor to put out the filter, this one have a female nut like a cable but but a bolt is inside and press on the inside filter and you are able to put out this one. Sometime you can found this filter which is like a isolator and sometime you don't need a tool to pu it out. You can't get HD channels with it but the only the base cable in RF. Do you have the VidA©0tron Internet or no service from them? Parlle tu framsais? |
Silver Member Username: BernardmiPost Number: 633 Registered: Dec-07 | Pipo says he lives in an appartment building Plymouth. Ce sont généralement des filtres télécommandables a distance dans le cas des blocs appartements. Rien a faire pour saboter les filtres. And those remotely addressable filter block resides in the Vidé_eau_tron locked access room. |
New member Username: ElpipoPost Number: 2 Registered: Aug-09 | Oui, je parle francais. Les filtres sont pas genre un pouces de long coax-in et coax out? Je remplace le filtre VDOtron, par un qui laisse passer les signaux des canaux spécialisés (i.e. RDS pour la saison de hockey). Ca se dévisse pas avec des pinces? J'ai pas regardé encore ou est la boite de VDOtron dans le bloc, ni ce que ca a l'air. Ou est-ce que je me procure les filtres, et autres kossins? Ca me prendrait des no de pieces, et un endroit ou les acheter. Merci |
Platinum Member Username: PlymouthCanada Post Number: 10657 Registered: Jan-08 | Pipo Bienvenue sur Ecoustics! Les filtreurs on environ 2" de long et 7/8" diam et les isolateur 2" de long et 1/2" de diam. Les isolateur prennent un outil mais pas les filtreur du moins je pense. ils ont aussi des nouveaux connecteurs type RG-6 avec un tube de metal dessus et tu a besoin d'une douille qui est fendu pour le glisser sur le fil et assez mince pour s'inserer dans le tube pour etre capable de le devisser. Le seul moyen que je peut voir est de garder le mAme et de percer pour vider son contenu et d'introduire un fil a la place pour obtenir le signal. Je n'ai pas le cable sauf pour internet et n'ai pas tente de le brancher mais c'est ainsi que tu peut proceder. As tu internet avec eux presentement ou t'as rien du tout? Bernard je ne connais pas la technologie dans les appartements mais il est possible que ce soit commande a distance, sauf si c'est un vieux building. |
New member Username: ElpipoPost Number: 3 Registered: Aug-09 | Sorry guys for us speaking french... C'est pour l'appart de mon pere, il est pas riche, donc pas d'internet ni de cable de base... Vieux building alors surement pas hi-tech. Bonne idée de vider le filtre, je vais voir dans la boite ce que ca a l'air. Alors il va y avoir un filtre, ET un isolateur, ou l'un ou l'autre? On vide l'isolateur ou le filtre, et il faut refaire des connecteurs coax apres? J'ai pas ce qu'il faut... Une place comme electr@mike ou sur le web, ils vendent pas des filtres / isolateurs, les pinces et tout le tralala que ca prends? |
Silver Member Username: BernardmiPost Number: 634 Registered: Dec-07 | Pipo et Plymouth prendre note que Vide_eau_tron installe ces filtres adressables meme dans les vieux blocs appartements. J'en ai vu moi-meme de mes yeux vus ! Rien rien rien a faire. Si on touche a la boite, ils le savent immédiatement. Danger ! Ces boites sont dans un local réservé a eux et barré avec leur cadenas. La je parle des gros blocs cependant. Genre 10 logements et plus. Sorry about using French folks. Want to make myself perfectly understood by my peers !!! |
Bronze Member Username: ArghhhhhhhhhhhhhhhPost Number: 30 Registered: Jul-09 | you can get a cable trap remover on ebay for 1$, the tool you need to open the box is called a gilbert tool. the best thing for you to do is remove the filter drill it out, and place a small piece of coax thorugh it, then put it back so it looks like a filter but is actually doing nothing....not that I know anything about this topic |
Bronze Member Username: XtremejohnjohnsonPost Number: 81 Registered: Jan-09 | My filter is removed and I'm getting HD channels. Of course you have to have a television that supports HD (tuner). |
Platinum Member Username: PlymouthCanada Post Number: 10670 Registered: Jan-08 | James It work for you! Where you live? in USA? |
