Kbox+Powerline Adapters=????
Username: Bosanel
Post Number: 17
Ok so I bought the Kbox prodigy yesterday and it works great!
That is when I use a 50 foot long ethernet cable that stretches from the second floor of my house to the main floor because I don't have 2 spots to plug both the satellite and my router (cable internet) upstairs. So I decided, lets save wire-hiding trouble and get 2 power line adapters and make it less messy and work a little less.
I've spend over 4 hours today trying to figure out why I can't seem to set them up. They are Ethernet power line adapters, so it's just plug and play.
I have tried connecting my laptop to the other adapter to test connectivity, no luck. I've almost given up and called someone to do this for me.
ANY help at all would be appreciated greatly!
Username: Saqeeb9000
Post Number: 5837
ok thats what happend with me too,
simple solution is make sure u plugged directly in to wall outlet don't use any extention cord,
let me know if this works
if it comes with cd, make sure u installed the cd,
what is brand name for ur power adapter?
Username: Bosanel
Post Number: 18
it is plugged directly into a wall outlet..
It's an Intellon 85 Mbps Homeplug Turbo ethernet adaptor...
no luck still :S
Thanks in advance
Username: Akhan64
Toronto, On Ca
Post Number: 7
I have same problem the KHUB light stays RED (does not blink). I connected the laptop with same connection it works. It means internet signals are ok.
Moreover I cannot edit DHCP and PPPoE connection information. All DHCP, PPPoE and Static are showing following informations
IP 192.168.0.0
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.0
DNS1: 4.2.2.2.2
DNS2: 4.2.2.1
Post Number: 5838
amir u need to change the mode in to static and then change the ip adress if u want to ,
and then change it to dhcp,
ip should be 192.168.0.105 etc...
try the factory reset button when u are in network mode
make sure u have latest file..
Username: Akhan64
Toronto, On Ca
Post Number: 9
sada,
do i need to activate KHUB? then how? I cannot save ip changed ip address into statis. The DHCP and PPPoE are not editable. I mean these are read only.
Post Number: 5840
http://www.dssrookie.com/forums/kbox-prodigy-files/100244-k1pro_201_20090625-a.h tml#post587356
k1pro_201_20090625
Version 2.01 (June 25, 2009)
KHub activation from receiver:
-copy KHub.rom to USB drive
-with KHub attached to receiver, power on
-Go to Menu: Utilities> Data Transfer> USB Explorer
_select KHub.rom and press OK
Username: Akhan64
Toronto, On Ca
Post Number: 10
thanks a ton for your help. Now i am able to see the green light. I have uploaded the latest bin as well, but still it is shwoing 'Wait processing....'
Username: Bosanel
Post Number: 19
No green for me, No connection even for the laptop.
Post Number: 5843
aamir khan if its green light then u should be able to watch tv, make sure ur setup is correct and u get good quality signals,
anel ssasa does ur adapter came with installation cd?
for mine there are 3 lights that come on on adapter,
no blinking lights,
check on urs
Username: Getmo96
Post Number: 162
make sure to activate the khub.
Username: Bosanel
Post Number: 21
Well, I decided, enough messing around. Went out returned the adapters, and for the same price got a Netgear network printer. Everything is working great now. Thanks for all the help guys!
Anel
Username: Akhan64
Toronto, On Ca
Post Number: 12
My Khub light is green. I have also scan all channel. but when I select any channel from list it always displays 'processing please wait....'
Please help.
Post Number: 5847
where is ur dish direction?
61.5
118.8
or 148
quick way to check is press info on any indo/pak channel
Username: Akhan64
Toronto, On Ca
Post Number: 14
My dish direct is 118 and 110. Do you think that, it's a direction problem?
Moreover my signal color comes in yellow color. What does it means? It used to be in green in viewset box. I haVe checked network connection as well, iT displays 'Connected - ok'.
There is a yellow button called 'Download' on Network information screen. What is the use of this button. When I click on 'Download' button, the KHUb light goes red and a confirmation message is displayed that download 1.62 is avaiable. When I click 'Yes' it display another messages 'download fail'. I tried 100 times. Each time same message. After this it takes a while to get back green light by KHUB.
Username: Akhan64
Toronto, On Ca
Post Number: 15
dear sada waiting for your response. :-)
Post Number: 5848
so far aamir no use of yellow button,
go to menu dish setting
ur sat for watching indo/pak channels should
be 118.8
lnb power on
type single
lnb freq 10750
22khz off
diseqc change it until u have 118 on top where it says dish setting right beside dish setting
u should get both level and quality signal
diseqc 1.1 and legacy should be turned off,
Post Number: 5849
the other easy way to do this for you
is to plug in ur viewsat box back
and go to dish setting
and write it on piece of paper and use the exact same setting on ur k1plus, (after replacing it with viewsat), leave the khub on ..
Username: Akhan64
Toronto, On Ca
Post Number: 16
thanks sada, your help worked. System is working greate for me.
