Difference HD vs HDTV?
Username: Otrsemidriver
Latham, NY USA
I have a 60" HD Not a HDTV, can someone please inform me of the difference please. My HD 1080p tuner does not show 1080i so well. I installed a HS HDMI it helped a weebit. I'm on time-warner cable and the 1080 channels are choppy or grainy, and changing from 480 to 1080 there is a green streaks as it blacks out for each change of channel or format. is that the green line of death? my unit is two weeks old. I have a DLP Widescreen it should be premo over a LCD or why would IMAX use DLP? also has anyone heard of LED DLP that Samsung Introduced, I have a Misubishi I like the 3D, however I was thinking that Mitsubishi should go LED asap. So whats the scoop on HD vs HDTV, did i make a better choice as most have HDTV. Thanks. Don
Username: John_s
Columbus, Ohio US
Post Number: 2444
"....does the set have a built in digital tuner or not? If it does, it's an HDTV; if it doesn't, it's HD Ready."
http://www.engadgethd.com/2005/08/30/hdtv-ready-vs-hdtv/
This article was written in 2005, when there were many displays available with no digtal tuner. Now, all TVs have digital tuners.
Need to Register?
Forgot Password?
Enable HTML code in message
