DisEqc Switch help
Username: Inswinger
Post Number: 7
I'm having trouble switching from different sats. I get great signals on some channels but on some i have 0 qualit. When I take out the diseqc switch and make a direct connection I get all the channels on that specific sat. So my guess is my diseqc switch is giving me the trouble. I/m currently using a chieta 4x1 and its about months old.
which is the best switch out there in the $20 price range?
And could you post a link for a reliable fta store where i can purchase it from?
Thanks.
Username: Plymouth
Post Number: 6920
Ace
I use this outdoor switch the only one that never broke Digiwawe DGS-41M:
http://www.digiwavetechnologies.com/index.php?module=pagemaster&PAGE_user_op=vie w_page&PAGE_id=95&MMN_position=97:5
Username: Jay_w_grayson
Prague, Oklahoma USA
Post Number: 265
Ace.....currently using a chieta 4x1
The 4X1 Chieta DiSEqC Switch is one of the best.
Username: Inswinger
Post Number: 8
Guys can you post any reliable store websites where I can buy a switch. I live in Brooklyn, NY. Is there any dealer here where I can pick one up?
Post Number: 266
Ace...You can get the switch here @ $10.00 each.
I always try to keep an extra one on hand. If this place is
too far from you just give them a call,
they will tell you what dealer is close to you.
Btw... good idea to put what they call rubber boots on the
switch ports connections, it will help to keep the Moisture out.
FtaGalaxy.com (a Leading Technologies Group Inc. division)
33-70 Prince St.
Suite CA-30
Flushing, NY 11354
516-684-9802
Username: Inswinger
Post Number: 9
FTA Tester
Thanks for the info.
Appreciate it!
