MANY CHANNELS MISSING!!!!!!
Username: Kildonan
Philadelpia, Pa Usa
Post Number: 15
I am using PANSAT 2700A i GET THE PPV FINE but no HBO,ADULTS,CINEMAX,SHOWTIME,ESPN,CNN, DISC ETC HELP ANYONE?
Username: Metallica
Post Number: 594
James go to channel edit delete all of your SAT..
And do a blind scan all of your SAT back again...than those channel will come back.
Username: Kildonan
Philadelpia, Pa Usa
Post Number: 16
THANKS MET, I'LL TRY that
Username: Kildonan
Philadelpia, Pa Usa
Post Number: 17
MET I have to delete the channels or just the sat?
Username: Metallica
Post Number: 595
delete the SAT..for example if you have Echo 7 than delete Echo 7..
than do a blind scan on Echo 7 all over again..so you don't have to delete 1 by 1 channel take forever..
Username: Kildonan
Philadelpia, Pa Usa
Post Number: 18
thanks
