Scaling
Username: Jonoates
My church needs to send a computer signal to a projector, a live camera video signal to two tv's. Also if I can attach the DVD player to this as well it would be good. Any ideas? I have looked at the Kramer electronics stuff but am not sure if it has what I need.
Username: Project6
Post Number: 7118
Did you ever solve this?
Username: Jonoates
no!
Username: Bobitza
Cluj-NapocaRomania
Hi everybody! I am just wondering
if I can watch a High Definition video stream from a Canon HV20 HD camcorder
(1920 x 1080, via HDMI output) fed into my 22" LCD ACER AL2216W TFT display.
This is 1680 x 1050 native, with DVI and VGA inputs only...
I guess I need a HDMI-to-DVI cable (or adapter) to feed the signal into the monitor.
But will I see the whole picture or just a portion of the frame??!! I think
the monitor is just doing a point-to-point job, while there is no downscaling
interface inbetween! Generally, how do you feed a Full HD video signal into slightly
lower resolution TFT devices, still preserving a nearly HD viewing quality?
I would appreciate any related hint from a more knowlegeable 'Ecoustics' member...
Thank you!
Username: Bobitza
Cluj-NapocaRomania
Hi! I forgot to say that the HD signal I mentioned above does not come as a "full HD" signal from the camcorder, but as a 1440x1080 HDV standard, with non-square pixels...
Still need to view it on a 1680x1050 display device, in a proper 16:9 ratio... What should I do to see it on a COMPUTER monitor, not on a 'Full HD' TV panel?... Cheers!
Need to Register?
Forgot Password?
Enable HTML code in message
