Easy question on HD Directv / Local HD broadcasts
Username: Griffin_andrews
Post Number: 35
All,
I'm confused about something and hope that one of you might help. I'm getting ready to cut a deal on a new HD TIVO unit from DTV and I'm hearing some buzz about a possible need for a separate antenna to receive local channel HD broadcasts.
I presently have local channels in SD through my current DTV deal. I guess I don't understand why there might be a need for a separate antenna?
What am I missing?
GA
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 28
Direct TV supplies all local channels in SD and HD here in NY city. If your TV has an internal ATSC tuner (hd tuner) you can pick up local digital HD stations over the air which you may use during direct tv outages.
Username: Efourdee
To receive HD you need a larger dish that picks up different frequency. This is required to pick up any HD channel. I believe this is what they are referring to.
Need to Register?
Forgot Password?
Enable HTML code in message
