Toshiba 27af43 service menu
Anyone know how to access the service menu for this model? Thanks.
. TV turned on
2. Press 'Mute' button on the remote.
3. Press 'Mute' button on the remote again and hold.
4. Press the 'Menu' button at the TV.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the item.
5. Write down the old value of the item before changing.
6. Use Volume up and down adjust the value.
7. When you have made all the adjustments you want turn the set off to exit.
TOSHIBA ALTERNATIVE:
1. TV turned on
2. Press 'Vol down' button on the set.
3. Press '9' button on the remote and hold.
4. Press the 'Channel down' button on the remote.
girlsfavtoy
Thx alot, i needed this :) I"ll try it out and see if it works out, thanks again.
