Horizontal lines on screen - help.
Username: Disc2
Hi, I'm new to home theater setup. I got an old Faroudja vp401 line quadrupler and all input and outputs work and tested fine. I am trying to connect it to an Infocus DLP projector but the video shows a lot of horizontal lines. The 401 works well with the with my vga computer monitor.
VP 401 outputs are RGBHV and VGA 15pin.
Infoucus had M1 input.
I have a vga to M1 cable that works fine from computer to projector but does not work with faroudja vga to the projector.
Any advice or help.
Need to Register?
Forgot Password?
Enable HTML code in message
