ProScan PS27123 & S-Video
Username: Kylen1010
Hello,
I just bought a s-video cord for my TV and I hooked everything up correctly. My problem is getting to view the s-video input. I do not have the original remote any more. Is there any way to view the s-video input without the original remote? Thanks a million!
Username: Dmwiley
Post Number: 451
How do you expect anyone to answer that question when you don't even provide tv make and model? And some of you complain about Knee Grow.
Username: Dmwiley
Post Number: 452
OOPS. My bad. Thread topic contains info. Does tv have flip down panel with buttons? Are there buttons on the rear?
Username: Dmwiley
Post Number: 453
Try here for remote assistance: http://www.proscanremotes.com/
Username: Kylen1010
The TV does not have a flip down panel only and no buttons on the back. The following buttons are on the front: +, -, Menu, Vol +, Vol -, Chan +, Chan -, Power. What do the descriptions mean for the model number PS27123? It doesn't make sense to me. Thanks.
Username: Dmwiley
Post Number: 457
Kyle, I'm sorry but I don't know this model. Try a "Google" search and maybe you'll come up with some useful info. I suspect you should be able to go into menu using the plus and minus keys and make the selection, but I'm not sure about this.
scottsomewhereintexas
Connect your S video source and make sure it's playing. On the front panel press menu until you get to setup menu and hit +. Then press menu again until it gets to autoprogram and press +. When it's done it'll have the S-video channel programmed in, probably channel 90 or 91.
I just found a shortcut. Press Menu and hold it. Then press Power and hold it. Then you can cycle through the inputs with Volume>. You could also buy virtually any cheapo universal remote in the world and set it up for the TV.
Username: Merda619
PS27123 ProScan problem....has power but can not get
menu to come on only thing shown is "parental control" please post suggestions.
Username: Scherrman
Post Number: 22
I have a suggestion. Buy better quality TV's.
Username: Be_brazy
Inglewood, Ca U.s.a
buy a plasma TV. more for your money kiddo.
Need to Register?
Forgot Password?
Enable HTML code in message
