Samsung DLP - Model HL56A650 problem
Username: Capnjeff
Hello,
I have this 56" Samsung. While watching it, it began switching off. The blue led on the manual switch remained lit. No audio/no picture. Then it would switch back on. It seems to be either an overheating issue or possibly a capacitor issue that is very common on the Samsung LCD sets. Then it progressed switching off immediately after turning it on. After awhile, it will come on. There's no predicting how long it will stay on. I'm thinking dirty/malfunctioning fan or blown capacitor or??? Any suggestions would be appreciated.
Username: Capnjeff
Okay, I've disassembled it this morning. No bulging capacitors. I tried to turn it on, it clicked, then turned off. Any suggestions?
Username: Capnjeff
I carefully took out the motherboard and ballast. Cleaned them up, checked the connections and re-assembled it. It's been a day and a half with no issues. That's good, I know, but I wish I would have found a problem. Oh well...
Username: Plymouth
Post Number: 15981
Welcome to eCoustics Jeff!
If the fan was dusted, the TV will fall in overheat protect mode!
Username: Capnjeff
I'll go with that. The TV has worked flawlessly since I cleaned it up. Lucky me... Thanks, Plymouth. .
Username: Zobeii77
Pakistan
Post Number: 16
Mark this post as Solved!!
Need to Register?
Forgot Password?
Enable HTML code in message
