Can't get HBO on my Fortec Lifetime ULTRA
Username: Kenan
I try to download the channels through the reciever but i cant get HBO regular only comedy and latino, can anyone help me PLEASE
Username: Lklives
Post Number: 1751
bummer...
Username: Al_bundy
Post Number: 17
sounds like you are only seeing one sat (110) which is why your only getting those 2 hbo's.
you also need to see sat 119 for the rest
Username: Lklives
Post Number: 1759
do sat scans..110 ..then 119...with NO switches from LNB to receiver..see what U get on both LNB's for satellite channels..if same, then both LNB's are pointed at same satellite...
maybe U have only 1 LNB...either way do scan without switches..
Username: Kenan
I have both 110 and 119, someone suggested i should do a TP scan, does anyone know which TP HBOE is on??
Username: Lklives
Post Number: 1772
Go to www.lyngsat.com and look for yourself..
Username: Turtleman
Fortec owner and haven't used in 3 months..how do i get it started again..what the recent bin?? can someone help me?? what to do?? thanks
Username: Cincy
Post Number: 33
louie low
dss community. c*m take out the *
sign in it is free look for forum read.
then go to files (fortec)it is all there waiting for u
