1 RF Input
Username: Ronharp
Help!
My in-laws purchased a Panny TH-42PX6OU. Many of the features that were supposed to be on the display were, in fact, not on the display when it was delivered. Most important is only one input for coax. they need one for OTA and one for Cable. Cable company has no cable card, no STB, and no HD so both inputs are important to them. Is there a way to get both cable/OTA into the set?
Username: John_s
Columbus, Ohio US
Post Number: 1128
An A/B RF switch would do the trick.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=180-422
Username: Ronharp
Thanks John
I was trying to avoid a switch such as that but ended up installing one anyway. My concern re that type switch was confusion. They no longer pick up new procedures like they once did. I explained that it will just have to do till some cable company or other change takes place.
Thanks again!
