Red tint in dvd picture using component in
Username: Tim360
New Zealand
Post Number: 8
I'm getting a bad red tint on the picture from my DVD player using the component video input for my Toshiba 29"CRT.
The colours appear normal when using the composite input from DVD to TV so it must have something to do with the component input.
I've played with settings on both DVD and TV but no luck. I've also upgraded component cables but no luck.
Any suggestions on this issue? Is it likely a TV or DVD player issue?
Need to Register?
Forgot Password?
Enable HTML code in message
