Hi, im having toubles finding headphones that fit in my MP3
Username: Psykith
Yah i just bought a new Curtis MP3 player and the headphone jack is to small for regular headphones to fit in it.Can someone tell me what this is called and tell me if i can just cut the smaller jack off and put it on a set of regular headphones?
Username: Illuminator
Post Number: 4897
How small are we talking here? Can you find a picture of the adaptor?
Username: Psykith
srry i dont have a picture of it but i would say its about 3mm jack.
Username: Psykith
ohh, srry it about a 2.5mm jack not 3mm.
Username: Psykith
the only headphones i found that would fit are cell phone headsets.
Post Number: 4967
They make an adaptor which should work fine for you:
http://www.amazon.com/Smartphone-Stereo-Headphone-Adapter-2-Pack/dp/B000KG8JHK
Need to Register?
Forgot Password?
Enable HTML code in message
