I need wiring advice for my 2 compR 12s
Username: Zv3482
Dallas, Texas
Hey guys. I'm installing a system in my altima coupe. And I've decided to go with the 12" Kicker CompR. 2 of them. They are recommended to run at 500 rms each. So I decided to go with the Hifonicis Brutus 1100.1 mono class d amp.this amp can run on 1 2 or 4 ohms. Any advice on which option of wiring would be best for my compRs performance and and any pointers?}
Username: Delsole
Post Number: 1835
Providing those subs are dual 2 ohm voice coils I think you best bet would be to run them at a two ohm load utilizing a series parallel.
Need to Register?
Forgot Password?
Enable HTML code in message
