Why 6.5" Car Speakers?
Username: Danmathew
United States
Post Number: 13
Researching on forums I came to know people are mostly fond of getting 6.5" speakers eventually. Important fact is 6.5" car speakers are the most highly suggested by the users because of their service and quality. Also it's easy to fit on your car audio system. Most new days cars are interested to take part on 6.5" because it's most modern & able to produce high quality sound. Also the dashing look.
All those purpose people are fond of using 6.5" car speakers. Do you have any ideas to share? Feel free to share it!!
Username: Jan_b_vigne
Dallas, TX
Post Number: 18476
Research "Thiele/Small parameters".
Username: Magfan
Post Number: 3469
that size speaker is likely to at least produce minimal bass in a car-size space.
The addition of a tweeter to make it a 2-way speaker will extend the high frequency response.
smaller speakers don't stand a chance of even minimal bass while larger speakers tend to also be Deeper and thus have more mounting issues.
In home use, you can get a full range, single driver speaker using a speaker in the 6 1/2" class and get very satisfying sound, just dont' expect gut-rumbling bass or ear piercing highs. At that point, knowledge of the TS parameters, (see post above) becomes necessary.
Dallas, TX
Post Number: 18477
https://www.eminence.com/support/understanding-loudspeaker-data/
http://www.tigeowners.com/forum/archive/index.php/t-6457.html
Need to Register?
Forgot Password?
Enable HTML code in message
