Cerwin Vega mid-range speakers
Username: Burtonde
Milwaukee, Wisconsin United States
I have a pair of Cerwin Vega
CLSC tower speakers. My grand kids for some reason destroyed the exposed mid range speakers. I want to replace them but I dont see any way to open the enclosures. Can someone help me.
Username: Burtonde
Com'mon guys, I really need yourr help on those Cerwin Vega CLSC-215 in replacing the mid-range speakers. How do I open the enclosures?
Username: Jan_b_vigne
Dallas, TX
Post Number: 18104
Why not simply contact CV?
If there are no screw visible on the front of the horn, then it typically attaches from the rear. To reach those attachment points you'll probably have to remove the woofer and work from behind.
Username: Magfan
Post Number: 3276
Yep:
In photos I can clearly see woofer fasteners.
Be carful, though, woofers generally have powerful magnets so find an out of the way place to put the woofer after removal.
Keep track of the WIRING, too, You don't want to rewire OUT OF PHASE.
I don't know how good a company CV is for stuff like this, but a good 'exploded' drawing of the speaker or even the mechanical assembly drawing would provide the needed information.
Username: Fonegi
what would a pair of vintage pristine Cerwin Vega PD9 special edition speakers cost. approx.?
DESCRIPTION: 15" 3-Way Loudspeaker
FREQENCY RESPONSE: 25 Hz --20 kHz
POWER HANDLING: 5/405 Watts RMS (Min/Max)
SENSITIVITY: 103 dB (1 Watt @ 1 Meter)
IMPEDANCE: 6 Ohms
LF DRIVER: 15" Die-cast Frame / 2" VC
MF DRIVER: (2) 7" Cone
HF DRIVER: 1" Voice-coil Phenolic Dome Horn
CROSSOVER POINTS: 250/3500 Hz
WEIGHT: 90 lbs.
DIMENSIONS: 36" x 17.5" x 19.25"
Dallas, TX
Post Number: 18366
As a salesperson, I learned early anything is worth what anyone is willing to pay.
Need to Register?
Forgot Password?
Enable HTML code in message
