Bose Lifestyle 20 CD cartridge is stuck
Username: Trb0428
Hi, I have a Bose Lifestyle 20 and the CD cartridge is stuck with the motor continuously running. I realize there is a CD Changer Manual Release on the underside but can someone describe how to use it. There are two openings but it is not obvious how to release the cartridge. I have tried poking around with a small screwdriver but am afraid I will cause more damage. Can someone describe which of the two openings to access (thin rectangular or wider square) and is there a latch/lever/etc that needs to be depressed to release the cartridge?
Username: Provenuts
You will find a slot just left of the molded sign "manual cd release". Shine a flashlight in and you'll see a U shaped cut out sheet metal on top of another piece of sheet metal. Stick a thin blade down against the U and pull away from the front CD door. Travel is about 1/2 inch til release. I got my cd cassette out but the cd still won't load. Good luck with yours.
Username: Abftech
There is some detailed instructions on how to repair this common problem. You can go to www.AnyoneCanFixIt.com and see the electronics section regarding the Bose Lifestyle 20 Series. If you can't get the CD magazine out by using the manual release on the bottom of the unit, the instructions will show you how to work around that too.
If you can get the CD magazine out, you will most likely have the problem of the unit just buzzing, buzzing, buzzing, and not able to load a CD to play. The instructions will show you how to fix that.
Username: Lmarreiros
PardePortugal
Your messages (some) are really helpful. I manage to solve my magazine release problem thanks to Claudio Fassardi. I think the cause of the stucking was a thicker CD, it's in the recycle bin already. Unfortunately before having read his post I tried blindedly to work the CD Changer Manual Release and so I released one of the 4 springs mentiones by others. Anyway I'm listening to my CD's once again and it didn't cost the crazy fees Bose charges.
Username: Acan
I did it! I got the CD Changer out. My daughter had put the CDs in upside down. However, when I righted them, it still won't play. Is there a reset?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3420
I gotta be the first Bose basher on here. I'm sorry, and this won't be very useful, but I've never heard of a CD player that locks up when you put a CD in upside down. Just brutal.
Username: Bigviv
$20 is a bit much for some instructions on how to repair something, whatever happened to helping the community?!
PardePortugal
My stuck CD magazine is now in the distant past. I am not a happy Lifestyle 20 owner, though. A much more serious problem has occured: as I switch on power a low tone noise appears and it's there all the time unless you increase the volume in order to hide it.
I haven't taken the whole set to the Bose assistance for the reasons we all know (to much time and money).
Has anyone have this problem before?
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 928
Humming noises generally are related to some sort of grounding problem either internal or external. Hopefully you have an external device that was recently added or some motor plugged into the same AC circuit that could explain the problem. Probably not but you never know!
Username: Luckyspike01
My Bose Lifestyle 25 had a humming sound coming from the Music Center, and it was related to the CD Changer being stuck. I used the manual eject slot on the bottom of the Music Center, following instructions I learned here, and inserted a long slim jewelery tool, and freed it. That solved the humming problem.
Thanks to all who take the time to record their experience and knowledge here.
Username: Justinmatthewbennettgm...
I had the same problem. CD magazine was stuck in my Lifestyle 20. I managed to get it out. However, it will even get stuck and make the same noise for an empty magazine. So I am suspecting a CD may be stuck inside or something is messed up inside. Thoughts? Advice?
Username: Gavdawg
Albany, New York
Post Number: 1476
have you tried calling bose?
Username: Tekrick
Anycity, Wisconsin USA
As of 9/14 bose will no longer be repairing the lifestyle series 20 music center. There are a couple things to keep in mind. If your player seems stuck and makes a humming sound, there are two motors in the unit. The nylon gears after time will split causing the shaft to turn inside the gear. After removing the CD carriage turn it upside down and with the ribbon cable still connected you will see the two motors and hear the motor turning. Most of the time it'll be the smaller motor gear that goes bad. If you care to repair it yourself you'll there's a way around it. The shaft is highly polished. I removed the gear and took a small rat-tail file and ran it length wise along the shaft to roughen it up and then used some epoxy, not crazy glue and attached the gear to the shaft. Wait at least two days for it to dry. That should do the trick.
Username: Audiolabga
We still repair the Bose CD-20 unit. Here are some tips.
http://alrepair.blogspot.com/2010/10/bose-cd-20-repair-notes.html
Username: Cupexperience
I was lazy and lucky, and have fixed the "displaced gear" problem, but with very little work.
I suggest people to try my method first and fall back to taking the main unit apart if my method does not do the trick.
My CD cassette would not eject. I heard the buzzing / motor-whirring sound.
- using the Next Disc button, I could see the discs moving in and out of the cassette.
- I was unable to use the manual eject slot until I had all the discs in the cassette and none in the player.
- when I could see all discs in the cassette (I had 2 empty slots, only 4 discs in the cassette), I pulled out the power cord from the back of the unit to stop the motor.
- Then I could use the manual eject slot to eject the cassette.
At this point I could see the worm gear and the black rollers.
With power reconnected and fiddling with the Next Disc button, the 2 black rollers then moved so I could no longer see the nylon gears.
I put 2 discs in the cassette, in the top 2 slots (slots 5 and 6) and put the cassette back in the main unit.
Repeat the process of using the Next Disc button, and as soon as the the CD came out of the player, back into cassette slot 6, I detached the power.
Use the Manual Eject slot to get the cassette out again. The gears will be visible and the 2 black rollers out of the way, at the top.
At this point I used a screwdriver to push the "mating gear" back onto its shaft. This is the drive gear for the worm gear you will see.
Link to photo at the end of this post.
I'm listening to a CD as I write this. :-)
Let's hope the gear is not cracked and that this fix does the trick.
I did not use glue, so I may have to repeat this process some day, but at least the player is working now.
Maybe I'll go back and add a dab of glue, accessing the gear the same way.
http://cupexperience.smugmug.com/Other/JJG-misc/i-HnfTgwM/0/M/Bose-Lifestyle-20- M.jpg
If this was helpful, the best way to say thank you is to visit my site about America's Cup sailing and sign up for the FREE newsletter.
http://www.cupexperience.com
Username: Jdaniel
Hi,,,, I got the same problem the cartridge is stuck, I check and found a small plastic weel on the turn pin of the motor, it is broken and can't be glued, anyone know where I can order a weel part like this ?
thanks...
if anyone can help here is my mail.
touitou01@gmail.com
Need to Register?
Forgot Password?
Enable HTML code in message
