Marantz 7001 turns off
Username: Vladsmol
Have this receiver for about 7 years, never was a single issue. Yesterday after turning PS ON played 10 minutes, then receiver turned off. Tried various suggestions to reset, keep unplugged, disconnect all speakers, nothing helped. The standby light blinking, after multiple attempts to turn receiver on once in a while getting error CHECK POW5. WAIT, then turns off again.
Would appreciate if someone could recommend the solution. Sounds yo me like it has to be repaired by experts.
Thanks in advance!
Username: Jan_b_vigne
Dallas, TX
Post Number: 17905
If the receiver powers itself down when there is no load (speakers) on the outputs and no input sourced, then likely you will need to have the unit repaired or replaced. Contact Marantz with your problem, possibly there's a factory reset you can try before you decide to take further action.
Username: Vic_718
Shenandoah, Pennsylvania United States
marantz 7001 same issue click on shut down immediate...... check pow 5 ----wait---- very aggravating when in need of a nice jam /movie session !!! opened unit dont see any loose white anything
Username: Vic_718
no load volume shut down completely nothing touching on speaker wiring no change
Need to Register?
Forgot Password?
Enable HTML code in message
