Pioneer receiver problem
Username: Jp82
I have a pioneer VSX-D307 A/V receiver and when i turn it on it will come on for a few seconds then power off will start blinking on the display and it will turn itself off.There is nothing hooked up to it no speakers nothing also the volume is turned all the way down as someone suggested could cause it but that aint it,what could the problem be?Is there a way to do a factory reset from the unit itself because i have no remote to it.Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 17922
Contact Pioneer technical support. They can give you an answer better than we can.
Username: Magfan
Post Number: 3162
Find out from the instruction manual just WHAT the blink means. Some gear has blink codes, so if it blinks say, 3 times, gap, than 3 times, it means something specific.
That is no substitute for a real tech, but at least you'll have SOME idea of where it's going.
Need to Register?
Forgot Password?
Enable HTML code in message
