Jbl e20
Username: Sixtoys
Hello
Im looking for stereo bookshelf speakers for music most of it.
I heard about those JBL ,but I cant understand if they are made to be part of surround or I can use them Just like that for stereo?
Thanks alot.
Username: Jan_b_vigne
Dallas, TX
Post Number: 17790
Speakers have no idea whether they are front or surround. Due to the small size of the speakers they will need to be paired with a subwoofer in either location. Placement of the sub relative to the speakers will be important for the best sound quality. If you're less concerned about sound vs looks, they should work as front speakers.
Need to Register?
Forgot Password?
Enable HTML code in message
