I just picked up a harman kardon pa 2400
Username: Insearchofbass
Post Number: 17217
I want to pick up some inexpensive 2 ohm speakers for it any suggestions?
Username: Jan_b_vigne
Dallas, TX
Post Number: 17388
Despite the way you read the literature, that amp will not drive 2 Ohm nomimal speakers. Try six Ohms or higher. What's "imexpensive"?
Post Number: 17218
well in that case ill run my nht classics at 6 ohms. Are you sure it wont do 4 ohms?
Post Number: 17219
the manual clearly states 8 and 4 ohm operation so i wont be afraid to go to 4.
