Speaker cable experiment with my Stingray
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 4231
I know this post should go in the cables section, but no one ever looks there.
When I was working in my garage the other day, I found some very thing solid core copper wire. I had enough to create two 6' braided pairs to try out. Man, was I ever pleasantly surprised! Before I was using Home Depot 12AWG, but this thin wire (I'm guess 20-22AWG) seems so much more clear, responsive and transparent.
Maybe I'm hearing things? But I don't think so.
Username: Stu_pitt
Irvington, New York USA
Post Number: 3974
Forget about brands, looks, prices, etc. It's all about the sound. If it works, it works. Everyone hears what they hear.
You can always dress it up with some Techflex, heat shrink, and some nice spades.
Username: Dmitchell
Post Number: 4233
Dressing them up is a good idea. I'm not feeling the need to upgrade cables right now.
Username: Nuck
Post Number: 15368
http://www.takefiveaudio.com/mall/default.asp
Username: Dmitchell
Post Number: 4236
Noooooo..... no new cables!
Username: Nuck
Post Number: 15372
That's where you can get the dress-up stuff, Dave.
Username: Dmitchell
Post Number: 4239
Ahh... gotcha.
Username: Dmitchell
Post Number: 4518
"I'm not feeling the need to upgrade cables right now."
I bought new cables.
Username: Hawkbilly
Nova Scotia Canada
Post Number: 1138
LOL. It's like when an owner is asked if he's going to keep the coach. Today he says "I love the guy, he'll be here next year", then tomorrow he fires him.
Username: Dmitchell
Post Number: 4519
LOL.. yup, it's exactly like that ;-)
Username: Superjazzyjames
Post Number: 696
To know if you really want to know what sounds better to you, run one type of wire to one speaker and one to the other. As you listen move the balance to one side, then the other. Keep the wire that sounds better and lose the other one.
Username: Jan_b_vigne
Dallas, TX
Post Number: 15626
You are forgetting the effects of the room on each speaker and the fact stereo channels are not identical not to mention moving the balance control will typically place you in a very off axis position relative to the speakers. You are also ignoring the concept of listening for anything other than "clear mids, tight bass and clean highs". I think there are more concise methods for selecting "better".
Username: Dmitchell
Post Number: 4520
My room is very unbalanced as well.
Post Number: 699
I've used that method many times Jan. It always worked out very well. Of course, this includes having the balance centered as well. In some cases, switching the wires between the two channels is involved. Yes, it means switching the wires at both the amp and the speakers, but it works.
Dallas, TX
Post Number: 15628
You get to listen to and for whatever you care to but I fail to see how this is a valid comparison of anything for the reasons I've stated above. If you're concerned with the music at all, this doesn't sound like it even takes the music into account. I'm sure you'll say it does but I simply don't know how it could. IMO this is like judging your preference for cofee or tea by putting one cup in each hand and deciding which cup feels hotter. It misses every major point of logic I can imagine.
Post Number: 705
ROTFL Jan! I won't argue my point since obviously all we can do is disagree. It works for me and it might work for David, nuff said.
Which coffee cup is hotter? Do you work with a lot of blonds? You don't sit down to a computer at work and find the screen covered with white out do you?
Username: Stu_pitt
Stamford, Connecticut USA
Post Number: 4218
What cables did you buy, David?
Username: Dmitchell
Post Number: 4528
There's a guy here in Ottawa who makes cables. He hand delivered them to my house the same day I ordered them. Good dude....
http://www.canuckaudiomart.com/userads.php?user_id=141
Username: Nuck
Post Number: 15623
Which cables did you get from Omer, Dave?
Username: Dmitchell
Post Number: 4529
Unity 12 AWG, terminated with bananas on both ends, thick black braid on them... very nice looking cables.
Post Number: 802
So what's better Dave, the wires you found or the ones you just bought?
Username: Dmitchell
Post Number: 4531
The ones I bought. But that's probably only cause I know I spent 100 bucks on them.
Post Number: 812
It's only a perception, don't let it die, keep it alive!
Username: Stu_pitt
Post Number: 4222
Trust your ears, David. You've been at this game long enough to know when something works well or not.
Username: Dmitchell
Post Number: 4538
Thanks for the vote of confidence Stu. I am a cynic at heart, which I guess sometimes makes it hard to enjoy new gear without over-analyzing it too much.
Username: Stu_pitt
Post Number: 4224
I know exactly what you mean.
Need to Register?
Forgot Password?
Enable HTML code in message
