Problems with McIntosh MVP 871
Username: Titozh
Mexico, D.F. MEXICO
Hello I have a problem with read SACD in the 871, it's read SACD in CD format, why can I do ?
Sometimes read in SACD but not forever....
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3305
Looks like you'll be sending it back to McIntosh.
Username: Jan_b_vigne
Dallas, TX
Post Number: 14188
Check your owner's manual, there should be a switch setting in the set up menu to default to a preferred format. If there is no switch or the switch has previously been set for SACD default (and hasn't reverted to another setting due to a power interruption), then you should make certain the discs are readable as SACD format. If you're certain the disc should play in SACD but will not set up as SACD, then do have the unit inspected by a Mac technician.
Username: Dmitchell
Post Number: 3319
If it's anything like my 301, it should just read the disc and adjust itself to the appropriate format on the fly. If you're putting in SACDs and the machine is reading them as CDs I would assume you have a problem.
Username: Dmitchell
Post Number: 3341
I often listen to my Mac system with my ugg boots on M.R.
Username: Nuck
Post Number: 14027
ugh!
Username: My_rantz
Gold CoastAustralia
Post Number: 2670
Does the Mac give you cold feet Dave?
Username: Nuck
Post Number: 14040
Jorge, since the sacd and cd playback are in different streams, it seems your Mac needs a 're-education'. See your local mac dealer.
Username: Dmitchell
Post Number: 3342
'Does the Mac give you cold feet Dave?"
Nah, I just look good with my uggs on.
Username: My_rantz
Gold CoastAustralia
Post Number: 2671
You gotta stop believing everything you're told Dave.
Username: Dmitchell
Post Number: 3343
lol! At least I don't wear them in public.
Username: Nuck
Post Number: 14051
Heavens no, they do not match your purse, urr, murse.
Username: Dmitchell
Post Number: 3345
But what if they *did* match? Would it be ok then Nuck?
Username: Nuck
Post Number: 14067
No white after Labor Day.
And the belt does not have to match, Herb.
http://www.youtube.com/watch?v=03M3hXYojqU
Username: My_rantz
Gold CoastAustralia
Post Number: 2675
Well, if it's cold enough to wear your ugg boots in public Dave, you won't need to worry about applying rouge. But keep up with the mascara and lip gloss to look at least half respectable.
Username: Dmitchell
Post Number: 3350
It gets cold enough here M.R.
For the boots, that is.
Username: My_rantz
Gold CoastAustralia
Post Number: 2676
I'm sure it does Dave - I'll swap you at the moment, it's 33 celcius inside here today
an getting hotter for the rest of the week.
I should bought AC instead of a pair of Xindak room
heaters lol!
Username: Dmitchell
Post Number: 3352
Nothing like a pair of Class-A space heaters!
Man, in a couple of more weeks I'll be praying for 33 degree weather.
Username: My_rantz
Gold CoastAustralia
Post Number: 2677
Maybe we'll all have to come and dig you out lol!
It's not just the heat, but the damn humidity here is a killer. Oh well, only about another 3 months of it.
Username: Dmitchell
Post Number: 3356
Speaking of digging us out M.R., we're supposed to get clobbered with our first storm of the winter. 20 cms tonight. Nick should get a nice amount, and maybe Nuck too.
Username: My_rantz
Gold CoastAustralia
Post Number: 2683
I hope it's not too bad - for all you guys in the frigid zone.
Make a snowman for me Dave - call it MR. Tallish, lean and muscular and extremely good looking :-)
Username: Dmitchell
Post Number: 3358
haha! Will do M.R.
I hope your nose resembles a carrot....
Username: My_rantz
Gold CoastAustralia
Post Number: 2686
No, not my nose.
Username: Dmitchell
Post Number: 3360
Doh!
Next topic.
Username: Nuck
Post Number: 14103
http://www.canuckaudiomart.com/details/153872-mcintosh_mvp851_player/
Need to Register?
Forgot Password?
Enable HTML code in message
