Ideas for a Preamp Under $300?
Username: Lovegasoline
Post Number: 147
I'm pretty much a beginner on a budget who has slowly been putting together a 2-channel system for the past three years.
My system consists of Yamaha Integrated Amp model A-700 (mid 1980's vintage). Sources are a Meridian 508.20 CDP and a Music Hall MMF.7 Turntable w/ Eroica Cartridge [the latter a high output MC Cart that is recommended to be run by a MM phone stage], Apple G5 as a music server w/iTunes (connected via cheap mini-plug > RCA cable), plus an inexpensive Philips DVD player for the occasional movie. Speakers are Polk LSi9s.
After putting upgrades on hold for a year, I just purchased a McCormack DNA-125 Amp and I am going to integrate it into my system. I had intended to use the preamp and MM phono-pre section of the Yamaha A-700 Integrated amp to feed the McCormack amp until I could afford a separate preamp upgrade in the future (I've been curious about the Audible Illusions M3A, but I haven't really begun to do the research for the preamp yet). Unfortnately, I can NOT hook the Yamaha's preamp section to the McCormack...there's NO pre-out. Gah!
In the interim, I need to get some sort of temporary preamp into this system to feed the McCormack.
Finances are VERY tight right now. A good preamp is out of the question as my audio priorities include numerous system expansion upgrades [I'll have two more rooms to supply with music in the near future, so I'll set up either a hardwired or wireless music server based on my Apple computer].
So now I need to take a bit of a detour.
Does anyone have recommendations for a premap (probably used) for under $300 that has switchable sources (CDP, AUX [Digital from Apple G5] , TT, DVD), MM phono stage, that will mate well with the McCormack and Polk LSi9? I listen to mostly rock with a little bit of everything else. I want something I can easily resell down the road, preferably without too big of a loss. This is a stop-gap measure. I haven't listened to tubes so I do not have an opinion on them vs. SS.
Any ideas?
Thanks a bunch.
Post Number: 148
I should add that buying used will likely yield more nag for the buck so take that into consideration if anyone has any recommendations.
Thanks.
Username: Nottingham365
MA USA
Post Number: 40
You might consider the discontinued Adcom GFP-565. (Please note that there was also a GFP-555 in the Adcom line). Some people consider it a fine value with a respectable MM phono stage. It features several inputs and two tape loops. On audiogon, it usually sells for around $300.00 or a little less. Ebay is another option. I think you could resell it downstream at a similar price.
Since the McCormack piece is high end, synergy might be lacking. But that may be the case with any preamp at the $300.00 price point.
Best wishes.
Username: Jan_b_vigne
Dallas, TX
Post Number: 13107
http://www.audiogon.com/cgi-bin/cls.pl?preatube&1231022217&/Dynaco-pas-3x-Tube-P reamp
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1232242649&/Rotel-RC-980bx
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1232149232&/Rotel-RC-1070
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1232167751&/Yamaha-C-85
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1232036659&/Superphon-Revelation -II-pre
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1231949096&/PS-Audio-4.6---5.0
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1231935307&/Marantz-3200
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1231725693&/NAD-C162
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1231710978&/B---K-Ref.-5-Series- II
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1231646092&/SAE-mark-xxx
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1231535698&/Rotel-RSP-976
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1231009551&/Adcom-GFP-555
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1230993506&/QUAD-33
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1230834162&/Quad-Model-44
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1230741227&/Perreaux-SA3-Class-A
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1230519390&/NAD-116
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1229888088&/Hafler-DH-110
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1229635596&/Van-Alstine-Pat-5-Om ega-Star
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1229267451&/Hafler-DH-110
http://www.audioclassics.com/detail.php3?detail=CITATION-11&nav=cat
http://www.audioclassics.com/detail.php3?detail=3300&nav=cat
There you go, 21 choices. There's some fairly decent stuff avaiable for $300 or less. At least 90% of it is better than the Yamaha A400.
Username: Mike3
Wylie, Tx USA
Post Number: 1541
JV, you belong in some kind of Customer Service position somewhere audio related!
Username: Mike3
Wylie, Tx USA
Post Number: 1542
Oh wait, that's going to end up being a been there done that isn't it?
Nice post above for the OP to work with.
Username: Afj
GaboroneBotswana
Post Number: 160
http://www.promitheusaudio.com/tvc.htm
havent heard it myself personally. maybe other members can comment
Dallas, TX
Post Number: 13110
It's a passive line control without a phono section.
Username: Hawkbilly
Nova Scotia Canada
Post Number: 422
Another option....
http://www.audio-ideas.com/reviews/preamps/audio-limits-preamplifier.html
Username: Nuck
Post Number: 11210
Get David M to try it first.
No phono.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 1763
Ha ha.
Yeah, I'll take one for the team.
Most of it is still under warranty.
Username: Dmitchell
Post Number: 1764
Hmmmm... try a low-budget made in China tube pre-amp.
Nevermind.
Post Number: 150
Thanks a bunch for all the great input.
For the outcome of this quest, please see the separate post here:
https://www.ecoustics.com/electronics/forum/home-audio/542884.html
Username: Milpai
Post Number: 14
Will a Promitheus TVC work with NAD C352 integrated's power amp section? These are the power amp figures that I got from NAD:
770 mV / 20k ohms / 470 pF
Thanks
Username: Milpai
Post Number: 16
Slow forum I guess. But anyways, I have orderd the Reference C-Core dual box TVC with Elma upgrades from Promitheus. Keeping my fingers crossed
Username: Milpai
Post Number: 17
Wanted to report back that the TVC works EXCELLENT with my NAD C352. The initial impressions after 1 hour are:
tightened up bass
superb separation
wide soundstage
each instrument has it's own space
vocals are superb
hardness is gone and music feels like it is floating free
Need to Register?
Forgot Password?
Enable HTML code in message
