VT-1 to PC Cable
Username: Robouser
Hello everyone. I just purchased a Boss VT-1 and need to connect it to my PC MIC IN connection. It will look like this.
Mic -> VT-1 -> PC
I need to know which cable I need to get to connect from the VT-1 MIC OUT connection to the computer MIC IN.
The connections on the VT-1 look like this:
Also, the manual for the VT-1 is located here:
http://uploads.shrike.us/BossVT-1manual.pdf
Also, are there any adapters that would allow a standard PC microphone (non-USB) to connect to the VT-1 INPUT connection?
Thanks for the help and links are much appreciated.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 2312
What does this thing do? You'll more than likely need some sort of adapter to connect this to your mic on your soundcard.
Username: Robouser
Thanks, I already found the adapters I needed.
Username: Nuck
Post Number: 11861
Another satisfied OP.
Cheers MH
Need to Register?
Forgot Password?
Enable HTML code in message
