Installation Questions for Audio Control Bijou Surround Sound EQ
Username: Frank1203
Post Number: 27
Helo, I just purchased the Audio Control Bijou Equalizer which has separate EQ settings for each surround sound channel.
I am a bit confused as to how to install it into my system. Let me explain.. Currently, my 2 front Paradigm Speakers are bi-amped to my Rotel along with the Center Channel. The rears are powered through my Rotel Surround sound Receiver along with the Subwoofer. So, since I have two distinct powering setups, how do I get the most out of the set up of this EQ? The advantage of this EQ is that it will control each 5.1 channel individually but I'm not sure how to make that work. Any help would be appreciated.
Username: Ustaad_hc
Post Number: 642
Need to Register?
Forgot Password?
Enable HTML code in message
