Help with ipod nano (3rd generation)
Username: Daisyj202
so the songs on my ipod take up a lot more space than they should. my sis and i have the exact same ipod: 300 songs on hers filled 2gb, but only 90 songs on mine filled 2gb. we both have average length songs (3-5 minutes each). ive also tried restoring the ipod to its factory settings without luck. most of my songs came from CDs. any ideas?
Username: Project6
Post Number: 15483
The space it takes up depends on the compression you used. If you are using 320Kbps or lossless format, your music will be higher quality but will take up more space.
Check how you rip songs from your CDs...what rate and format.
Username: Joy284
China
Post Number: 12
Maybe your songs storage is lager,or all of your songs are mp3 format.You should download wma formats song.
Username: Eatisa
Post Number: 7
i got so fedup with my iPod that now i am planning to get a 120GB Zune... waiting for 8th Sep for the launch
Need to Register?
Forgot Password?
Enable HTML code in message
