On the Behringer DEQ there are square S/PDIF and XLR AES/EBU connections, but no coaxial digital out like I'm using at the moment between DVD player and DAC.
Na, no S/PDIF. Only one input. I'm told by its maker that Behringer should have used coaxial rathaer than optical as it has less jitter. Wonder what the consensus is on that one.
Also been told I need to buy a converter. Hope it's lossless. Could have done without another powered item the system - its starting to look like a 747 cockpit.
