Dead DAC
Username: Nuck
Post Number: 8534
My Classe DAC-1 stopped working, so I cracked the case for a look.
The cap array is intact, except for the primary feed, via a discrete CR.
The path is blackened between the CR and the first cap, which seems to have blown it's azz.
Blown on the tracers, not the cap top.
This is most dissapointing.
How much current was flowing, and from where to let this happen?
I can pull the board and replace the componants, but with the same result?
Ideas on where to put my leads? other than the obvious?
Username: Jan_b_vigne
Dallas, TX
Post Number: 11215
Do you have a schematic to tell you how much voltage to expect at each junction?
Username: Nuck
Post Number: 8544
no, but I called.
They said ahh...no.
I know, off to the shop I go.
Ratbastards!
Dallas, TX
Post Number: 11217
A Communist, Liberal, pinky, red diaper doper baby, Socialist pig plot if ever there was one. Whadda ya expect when you engage in Capitalism?
Username: Nuck
Post Number: 8552
I ain't even got a garage, you can call home and ask my wife!
Then he started sayin' somethin 'bout the way I was dressed...
Need to Register?
Forgot Password?
Enable HTML code in message
