Which type of cd(blank disc) should one use to record?
Username: Shane24
Post Number: 27
yeah, i recently bought a denon double cd-recorder.. i guy at the store said u need to use a different type of cd to record, not the usual pc type one..
what type is he talking about then?
and where would i get them.. any links..?
Username: Stryvn
Post Number: 65
Why didn't you ask the "guy at the store" these questions before you plopped down your schpondulies???
And where do you come up with this stuff, dude?
Username: Shane24
Post Number: 29
i did... the problem is he himself wasn't to sure where do get them from..
Username: Stryvn
Post Number: 66
got it from the white van, huh?
Username: Alright_boy
Post Number: 60
Maxell, Sony or TDK will do nicely thank you. Try here for great selection and competitive prices:http://www.tapeworld.com/
Need to Register?
Forgot Password?
Enable HTML code in message
