Revel F-32 speakers
Username: Mmeyers1984
I've looked at several brands of speakers and have been very impressed by Revel f-32's at $2,000 each as the speakers for a two channel stereo system. Any thoughts? What else should I consider?
Username: My_rantz
Australia
Post Number: 1086
Mike, there are hundreds of them and we could all tell you our favourites and that would mean nothing as it is your ears and your satisfaction that counts - not ours. Listen to as many as you can under similar conditions as possible (room, amps etc) and choose what tickles your fancy. Others may want to give more information, but you'll probably need to state your room size, amplification, source and so forth to give them some sort of starting point.
thanks. It's sure hard when there are so many choices and no one carries more than one or two brands. That makes it very hard to compare.
Username: Philipt95148
Post Number: 45
Try Triangle Antal ESW.
I heard it through a MacIntosh components set up and nearly spent the money (that I don't have)
I previously heard the same components with B&W 802D and was sure the Triangle was up there with it.
Username: My_rantz
Australia
Post Number: 1090
Mike, it's the same problem where I live. Luckilly I had a dealer who offered to refund our speakers if we didn't like them. Even though I am pleased as punch with ours, I still would have liked the opportunity to audition many more. Maybe it's better what you don't know! Try for an in-home demo if you can.
Username: Frank_abela
Berkshire UK
Post Number: 1888
Mike,
What electronics are you pairing them with?
What size room are you trying to fill?
What musical tastes have you?
How have you been impressed by the Revels? (Not disputing, just wanting to know your experience so far.)
Regards,
Frank.
I may pair the speakers to a 1052 rotel or maybe NAD equipment. I heard the revels compared to some B&W's of similar price and they were much much better.
