Question about Adding onto the JVC HX-D77
Username: Joshizzle
I got the JVC HX-D77 for my birthday. And it has extreme bass, enough to shake my bedroom. But I was wondering if i could add on more.
http://www.jvc.com/product.jsp?modelId=MODL027644&pathId=13&page=2
There is the link to it.
The back of it has ports to plug in the subwoofer to, and each speaker has two different places for the sub woofer. a black and red wire for each sub woofer in the speakers.
I was wondering if you could like hook it into an amp, then hook the sub woofer cords to the originals speakers for the jvc hxd77 into the amp, then hook another sub into that amp. or something like that.
Username: Joshizzle
Here is a picture of the wire ports i was talking about
http://i11.tinypic.com/2pttl5v.jpg
Username: Gabeomatic
Hey, I dont know how to add any base, maybe you can connect subs or more speakers.. but I wanted to ask you if they system has good bass.
I was thinking of getting this system but I need something with really good bass.
I've heard jvc is concentrating too much on the looks nowadays, but my friend has the JVC Mx Gt-90 and that system has the best bass ever, i dont know whether too try and find that one even though it cam out a while ago.
It has 460 watts, but 8 inch subs instead of this ones 6 5/16 inch.. Both looks beastly tho.. any help?
Need to Register?
Forgot Password?
Enable HTML code in message
