Help, I'm not high tech! TV sound through stereo
Username: Kbpuckman
OK guys, I'm not high tech but need some help. I have a new sharp 37" flat panel LCD and want to know how to get TV sound through my stereo system. I have a Denon M51 DVD integrated player that sounds OK with 2 Bose 301's. I have the TV hooked up with the standard 3 wire cabel. Do I need to run more wires to get TV sound or am I missing some thing in the manual?
Username: Jan_b_vigne
Dallas, TX
Post Number: 9408
Do you not have sound or do you not have good sound? Your owner's manual for the integrated player should provide the information you need. Check in the TV's manual for any instructions that might indicate you need to switch on an output to provide a signal to the amplifier.
Username: John_a
LondonU.K.
Post Number: 4594
Kevin, probably you just need to get a cable and connect "audio out" on the TV to any input on the integrated player.
Need to Register?
Forgot Password?
Enable HTML code in message
