Pre-pro with digital outputs
Username: Jhenderson
Moorpark, CA USA
I am looking for a pre-pro featuring SP/DIF digital outputs instead of D/As for each of the 5.1 or 7.1 outputs. This allows me to use my own D/As and active crossovers to drive each speaker. The only unit I've seen that will accomodate this is the Meridian G68J. I am primarily interested in DSP music modes such as Dolby PLIIx, as this unit will be used in my primary audio rig.
Can you recommend any other pre-pros that support this?
Need to Register?
Forgot Password?
Enable HTML code in message
